Robust CAN Electrical Measurements in LabVIEW — Handling Ringing and Overshoot with PXIe-5111
Hello NI Community,
I am developing an automated CAN physical layer validation system in LabVIEW using a PXIe-5111 oscilloscope. The goal is to validate CAN electrical characteristics against ISO 11898-2.
Test Setup
  • Oscilloscope: NI PXIe-5111
  • Driver: NI-SCOPE in labview
  • CAN speed: 250 kbps (Classical CAN, ISO 11898-2)
  • CH0 → CAN_H
  • CH1 → CAN_L
  • Probe: 10x passive probe, 1 MΩ input impedance
Acquisition Settings
  • Sample rate: 10 MS/s
  • Record length: 50,000 samples
  • Trigger: Rising edge on CH0 at 3.0V
Measurements Being Performed
I am currently validating:
1. Bus Voltage Levels
  • CAN_H dominant/recessive
  • CAN_L dominant/recessive
  • Differential voltage (Vdiff)
2. Differential Signal Characteristics
  • Peak dominant Vdiff
  • Recessive Vdiff floor
  • Peak-to-peak differential amplitude
Thresholds are derived from ISO 11898-2:2024:
  • Table 3 → recessive state
  • Table 5 → dominant state
Current Measurement Method
My current LabVIEW flow is:
  1. Initialize NI-SCOPE
  2. Configure vertical/horizontal timing
  3. Configure analog edge trigger
  4. Acquire CAN_H and CAN_L waveforms
  5. Extract Y arrays
  6. Use:
    • Array Max → dominant levels
    • Array Min → recessive levels
  7. Compute:
    • Vdiff = CAN_H − CAN_L
  8. Compare against ISO thresholds
  9. Generate PASS/FAIL result
Problem Encountered
The issue is that CAN edges contain ringing and overshoot artifacts.
Because I am using raw Array Max and Array Min, even a single transient sample can corrupt the measurement.
Example:
  • True dominant CAN_H level ≈ 3.65V
  • One ringing spike reaches 4.10V
  • Array Max reports 4.10V
Similarly:
  • Recessive ringing can briefly drive Vdiff slightly negative
  • Array Min then produces false failures
So the measurement becomes sensitive to edge artifacts rather than representing the steady-state bus condition intended by ISO 11898-2.
Approaches I Am Considering
1. Percentile-Based Measurement
Use a percentile (95th/99th) instead of raw max/min.
Pros:
  • Simple implementation
  • Rejects isolated spikes
Concern:
  • Percentile selection feels somewhat arbitrary for compliance testing
2. Histogram / Cluster-Based Measurement
Use histogram analysis to identify dominant and recessive voltage clusters, then calculate the mean of each cluster.
Pros:
  • Physically representative
  • Similar to oscilloscope statistical measurements
Concern:
  • More implementation complexity
3. Threshold-Masked Mean (Current Preferred Approach)
Create a dominant-state mask using:
  • Vdiff > 0.9V
Then:
  • Extract only confirmed dominant samples
  • Compute mean CAN_H / CAN_L values from masked samples
This naturally excludes:
  • recessive bits
  • transitions
  • ringing regions
This feels closest to measuring the actual steady-state dominant bus voltage.
4. NI-SCOPE Built-In Measurements
Use NI-SCOPE scalar measurements such as:
  • VOLTAGE_HIGH
  • VOLTAGE_LOW
I understand these internally use histogram/statistical methods.
However, I am unsure whether they are appropriate for a two-state CAN waveform versus a more traditional periodic digital waveform.
Questions
  1. For CAN electrical compliance measurements, which methodology is generally considered most appropriate?
  2. Are NI-SCOPE measurements like VOLTAGE_HIGH / VOLTAGE_LOW suitable for CAN waveforms with dominant/recessive states?
  3. Is the threshold-masked mean approach considered valid for ISO-oriented automated testing?
  4. Has anyone implemented a similar CAN physical-layer validation system using PXI hardware and NI-SCOPE? If so, what measurement strategy did you use to avoid ringing-related false readings?
Any guidance or practical experience would be greatly appreciated.
Thank you.
Message 1 of 1
(493 Views)
