LabVIEW+Hypot ULTRA 7804
Hello. I'm currently performing tests using a Hypot ULTRA 7804 and LabVIEW. I'm planning on doing  multi-point tests using two secondary  high voltage models SC6540. Using Hypot ULTRA's LabVIEW drivers and library. I found a VI which allows me to configure the scanner (SC6540). I would like to know how can I configure my device to perform automatically 3 IR tests and 6 DCW tests. Thank you in advance for any help.
(1,334 Views)
Hi andre,
By creating a "main" VI that calls the needed functions in the correct order! (This is called "programming"…)
(1,306 Views)
for scanner (SC6540), you need to download seperate drivers package from https://www.arisafety.com/support/instrument-drivers
the Example code is provided to control the Scanner scannels with High Voltage, Return and Ground Bond channels.
Sathish Kumar A
Certified LabVIEW Architect (CLA)
(536 Views)
