Synchronizing displacement sensor and camera
i need some help regarding implementing a synchronizing diagram(producer ,consumer ) ...i couldnt delete some of the blocks(eg:transform block,etc.) in labview and some errors which i couldn't find whats wrong if anyone can help just reply i will connect
(823 Views)
You don't provide sufficient information to diagnose.
  • What are the error messages you get?
  • What is a "transform block"?
  • What is a "synchronizing diagram"?
  • Can you attach your VI?
(811 Views)
here im unable to delete the block but just the connections are able to delete
(802 Views)
I said "attach your VI". Showing a truncated code picture is not helpful.
How exactly are you trying to delete and what happens when you try?
(760 Views)
(715 Views)
What kind of camera are you using? Some industrial camera support triggering that can be used for synchronization.
https://tmesystems.net/
(683 Views)
It's a lab camera in my school lab..i was asked to do syncronisation for that with a displacement sensor in which i made the consumer and producer loops ..could you fix the diagram..?
(603 Views)
