I have a pci mio-16e-4 board and im trying to run a simultaneous AO operation and counter operation. I have been able to do this with regular NI-daq functions but havent been successful with daqmx. I believe the problem lies in routing the signal. With regular DAQ i was able to route the AO update signal to PFI 5 and then use that for the counter gate. With DAQ-mx, i assumed the AO update name was changed to AO sample clock, so i routed that to PFI 5. However, when i run the program i get an error (in the counter part) that says i cannot select sample clock and must choose implicit, or on demand. This error (code:-200300) occurs in the daq-mx read vi after the sample clock has already been selected?! I guess another question would be is the sample clock vi analogous with the gate.vi from the older version. Thanks in advance for any help.
