Run DAQ at multiple timings?
All,
I have a cDAQ-9172 loaded with 4 NI 9239 modules. I'm content sampling all of the channels these modules provide at about ~500 S/s however I have one channel that I need to sample at about ~15000 S/s. Is it possible to have this DAQ module sample at various speeds? The obvious thing to do is bump all the channels up to 15k S/s and downsample, however this can be quite a processing load. Any suggestions?
Ken
(3,003 Views)
With the cDAQ you are locked into one AI Sample Clock and only one task for all Analog Input Channels. Downsampling sounds like the next best option.
Amit
(2,985 Views)
