maximum external clock
I am trying to use a PCI 6259 board to generate a periodic analog waveform based on an external clock of which the frequency is ~15 MHz. The external clock is from a CCD camera.
I set the external clock rate to 15 MHz in the front panel. When I run my program, the 'actual sample clock rate' indicates 0 Hz and the error message comes out; frequency => sampling rate/2. Then the next message is that the maximum clock frequency is 10 MHz. I attached the diagram I wrote.
I think the error occured in the basic function generator.vi. If you know how to solve this problem, please let me know.
Thanks.
(3,054 Views)
I don't think the 6259 can run at 15 MHz!
Amit
(3,031 Views)
