Run Labview exe silently
Hi all,
I want to be able to run a Labview exe silently. I am aware that you can use VI properties to hide or make the front panel transparent when the main VI runs. However, when the application runs the front panel still "flashes" before it disappears. (I guess LV loads the runtime engine etc. before it gets to the bit of the code that makes the front panel hidden.)
Is there any way to run an LV application with a hidden front panel without this flashing effect? I want to run it completely silently, without even a minimised icon.
Thanks for listening.
Message 1 of 14
(8,034 Views)
Have you configured the VI's Run-Time Position to "minimized" in the VI Properties?
You could resort to running the app as a service. There's a KB article that describes how to do that. If you search the NI site you'll find it.
Message 2 of 14
(8,003 Views)
One other thing you can do is edit the .ini file.
Add this HideRootWindow=True
This will take care of hiding the icon on the taskbar.
Cory K
Message 3 of 14
(7,992 Views)
Actually, it doesn't. That just hides the initial splash screen. It doesn't hide the button for the actual build application.
Message 4 of 14
(7,979 Views)
Oh... Smiley Tongue
Maybe I'm confusing it with another property.
I very rarely mess with the ini files of my applications,
but I know theres a property in there somewhere that can hide the application on the taskbar.
Cory K
Message 5 of 14
(7,965 Views)
That would be "useTaskBar". However, all that that does is display the window's title bar only in the lower left part of the screen right above the taskbar. Doesn't seem like much of an improvement to me.
Message 6 of 14
(7,963 Views)
According to me, and my experiment I ran a few seconds ago, Cory is right, HideRootWindow=True does indeed hide the app on the taskbar.
Richard
Message 7 of 14
(7,945 Views)
It doesn't with me. Perhaps it's OS dependent?
Message 8 of 14
(7,937 Views)
It is. I run XP at work.
Richard
Message 9 of 14
(7,931 Views)
I am using a small app that is called Hstart to silently run programs from the commandline. It is an invisible commandline prompt, so you can execute an .exe without popping up. Im not sure if it will work with a labview executable,
but if you have configured all front panels to be invisible this might work.
http://www.ntwind.com/blog/hstart-v1.1.html
I use it in my labview apps to call commandline pdf generation tools. it makes me nice pdf reports without any popup and just saves it in a specific location. Its not a pdf printer but really a document generation tool (LaTeX).
Message 10 of 14
(7,929 Views)
