Run Labview exe silently
One way would be a windows system service.
http://zone.ni.com/devzone/cda/tut/p/id/3185
But there are some operations you wont be able to do (File dialog).
So far I only have used this together with a program that controls the Service and has the FPs showing, but the service is restricted to not showing it (by Win).
Felix
Message 11 of 14
(1,676 Views)
Something I can recall from the past but I didn't check it.
Did you try configuring the window of your vi 'no title bar' and such?
HideRootWindow=True to my understanding only disabled the 'lvrt'dll' item on the taskbar.
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
Message 12 of 14
(1,626 Views)
  • Go to VI Properties (Ctrl+I).
  • Under Window Appearance click "Customize"
  • Check "Window Runs Transparently". Set Transparency to 100%
  • Un-check "Allow User to Minimize Window"
If a window cannot be minimized, Windows will not show it in the taskbar.
You can also use a VI property node to set the Front Panel state to "Hidden". But the key is to un-check "Allow User to Minimize Window".
Make sneaky background processes! Fool your friends and coworkers! Fun for everyone!
Message 13 of 14
(1,605 Views)
For me, this works only if I start the VI as VI, but not if I use the VI as an executable. Im am using Win7.
Is there any other way to do this?
Message 14 of 14
(1,197 Views)
