Run SCXI 1121 with Daq Card Without Chassis?
If I connect an appropriate power supply to a SCXI 1121 module,which
has the capability to operate in parallel mode with a daq card,will the
module work with a PCI 1200 without the SCXI chassis? It would be used with
LabView 6i or NiDaq drivers. Thank you for your consideration.
(2,566 Views)
Hello Ron,
You will need an SCXI chassis in order to control and program the SCXI-1121 module with a DAQ device.
Todd D.
NI Applications Engineer
(2,566 Views)
