"List Directory" function performance decrease in Labview 7
I have a Labview program that the user inputs a .pdf file name, and the program searches through a nested directory tree and opens the .pdf if it finds it. The program uses the "List Directory" function in a loop to first build an array of all of the subdirectories in the main directory. The program worked fine in Labview 6.1 and earlier - consistantly found the file in less than a minute. However, when I upgraded to Labview 7, the search now takes 7-8 minutes. A call to National Instruments said that I am the second person to report the issue, but it is too new to have a work around yet. Does anyone know of another way to do this without the "List Directory" function that would perform much better with Lab
view 7?
(3,139 Views)
It could be the build array in a loop that's causing the performance hit. Have you tried initializing the array to a set size first?
(3,139 Views)
As mentioned in the other posting, this could be due to something else
on the diagram. If you are pretty sure this is indeed caused by a
slowdown in List Directory, could you give more detail about the OS and
perhaps a simple example showing how you are making the measurement.
Send it to ni.com/support.
Greg McKaskle
(3,139 Views)
