Run a set number of times, toggling boolean functions
Good Morning!
I have two things I cannot wrap my head around.
The attached vi is meant to be a sub vi.
1) How would I get he program to run a set number of times, CW and CCW. I'm aiming for 4 times, but I will have to make another sub vi for another motor that will have to switch directions every 2 hours for 48 hours. That would be a lot of copy and paste 🤣
2) This one feels so much more simple than it should be.... How can I control that sub vi from a boolean function on the main vi?
Please help!
Message 1 of 8
(1,978 Views)
It's not perfect but I think this will give you a better idea of how I would accomplish this
=== Engineer Ambiguously ===
Message 2 of 8
(1,934 Views)
I cannot open it since I am running an older version 😞
Would you be able to 'Save for a previous version'?
Message 3 of 8
(1,854 Views)
I cannot open newer version 😞
Would you be able to save it as 2018 or older?
Message 4 of 8
(1,916 Views)
Accepted by NoobGee
Here you go...
Message 5 of 8
(1,908 Views)
Why does it need to be a subVI and how are you actually plan to call it? We need more context!
(Your local variables have absolutely no purpose! Why would you use a signaling property if you don't even have an evet structure??? I think you need to start over with the very basic tutorials about dataflow before going further with this project. If your VI uses a typedef, make sure to attach it!)
Not sure why you have so...much...code for such a simple problem.
Message 6 of 8
(1,882 Views)
Here's a quick draft framework how you could cycle through all states in order. It definitely needs more details.
Message 7 of 8
(1,851 Views)
Thank you both so much.
At least now I have an idea of what direction I should take. This part of my project has been a pain.
For reference the attached vi is what this is needed for.
The local variables are just place holders for reference.
Message 8 of 8
(1,843 Views)
