Run and Exit button on application
Hello,friends! I have some problem and I'll be thanked for any help! I want to create application from my VI with application builder. I want to take away all standard toolbars and buttons when application will be using. So,to do it I must to create Run and Exit buttons in application. But i do not know how to do it 😞 It will be cool, if anyone will divide by example of VI, which will contain function for this buttons! Thanks!
(8,348 Views)
Accepted by ST-Peterburg
here is a vi attached..just an example 9hittimg stop button will quit Labview)
If you do not want to see the menu bar or the scroll bar then CTRL+I->VI properties->Window appearence->customize and select from the option to customize accordingly.
Also if you want to stop and quit the application use the "Quit LabVIEW" function available
Regards
Guru (CLA)
(8,341 Views)
Thank You,Guruthilak! ALL WORK! 😉
(8,333 Views)
Stop and quit/exit functions are available but there is no run button/functions how to add run on vi without the actual one?
"Thanks with regards "
by
..........Gireesh..........
(8,106 Views)
Hello Gireesh,
After reading your post, I am not exactly sure what you are looking for. Could you explain in more detail what you would like to do?
Jim St
RF Product Support Engineer
(8,075 Views)
Your name sounds familiar.  Didn't we show you this in another post?
19427i4D8D5FC5D8E9B870
- tbob
Inventor of the WORM Global
(8,063 Views)
