Run any number of re-entrant VI's
I'm trying to create a VI that will concurrently run any number of re-entrant subVI's. After looking at many examples, the one that best replicates the behaviour I want is found at \examples\general\Reentrant Panels.llb\Reentrant Panels.vi.
My problem is that this example only runs up to two subVI's. How would I change this behaviour so I could run as many as I wanted? For loops don't seem to work because the first subVI must be stopped before the next will be run, and I need them to run concurrently. Here are a couple methods I've tried (all using for loops):
I've also attached the Labview example in case you don't have it.
I haven't yet found any examples or posts that achieve this behaviour, and I'm fairly new to this area of Labview, if you could point me in the right direction it would be much appreciated!
(2,722 Views)
You might want to have a look at the Asynchronous Call By Reference.
GCentral
(2,704 Views)
What LabVIEW version do you have? If you configure the FOR loop for parallelism,  iterations can can run concurrently, up to the number of parallel instances configured.
(2,702 Views)
Accepted by topic author lauraalkhoury
Method 2 should work fine.  It should spawn new subvi's every time it is called.
This method calls the following and it spawns 3 new subvi's every time it is called.
(2,699 Views)
@ altenbach Parallel processing would be ideal, but this VI will be much larger eventually, running on machines with potentially only one processor. For the record I'm using LV 2011 Professional.
(2,628 Views)
You still get parallel instances, even if you are only running on one CPU, so the end effect should be similar.
(of course the number of parallel instances is limited to 64).
(2,622 Views)
