Run code without usual labview buttons
smercurio_fc wrote:
Yesh wrote:
Still stuck at the same problem. Forget the
above posts where I wanted to run the Vi
when they are opened. Is ther any damn way
to run the code without using then Run button,
not using CTRL+R, and not Run the VI when its
opened. I want to create a custom Run button on
the front panel. thats it
This has already been answered. Answer: NO.
Unless you do something flashy like use an Xcontrol http://forums.ni.com/ni/board/message?board.id=170&message.id=457607&query.id=1227148#M457607
Message 11 of 13
(897 Views)
Yesh wrote:
The biggest problem witht he Run when open the VI
is when you stop the execution of VI, you cannot restart
it agin unles you have acces to run button.
If the VI is set to run when openend, there should be no easy way to stop execution, so there is no need to restart it, ever.
In a proper state machine, you'd just go to an idle state, for example.
Message 12 of 13
(891 Views)
I thought I was in this thread, which asked the same question, and in which I pointed out that XControl. These same questions asked over and over again make me deja vu nautious. Smiley Very Happy
Message 13 of 13
(868 Views)
