Run part of code once if user presses button
Hi all,
I am trying to run a portion of my code only once if the user presses a button. If the button is pressed once more the code should run once more as well. Is there a simple way to accomplish this?
The strategy I took was encasing the relevant portion of the code in a case structure which is controlled by a boolean switch. This case structure is then enclosed in a while loop. My thinking is that the while loop continuously checks the boolean and if it is true the code within the case structure is run. However, the issue with this is the code might run more than once even though ideally I want it to run only once. Additionally, I'm not sure if it's poor arrangement to have the code continuously check the while loop. I attached a labview file demonstrating this.
Is there a more simple / cleaner way to accomplish this? Thanks.
(2,280 Views)
Yes.  Take any of the LabVIEW Introductory Tutorials that introduce the major Structures (the first section of Palettes in the Block Diagram) and explains when, how, and why you use them.  Pay attention to those that are "other than" the While Loop and Case Structure.  Look at the examples.
(2,256 Views)
Accepted by KnicksFan
@KnicksFan wrote:
Hi all,
I think an event structure is what  is referring to (I'm also new, but I've seen it done this way). Looking at your code, it looks like you can get away with putting everything in a event structure that runs when the switch is pressed. (If any of the more experienced members correct me, listen to them)
Here is a basic video on Event Structures
https://www.youtube.com/watch?v=V8Yk8MdLUII&t=27s
Here is a page on event driven programming in LabVIEW
https://www.ni.com/en/support/documentation/supplemental/06/event-driven-programming-in-labview.html
and a page on Event Structures
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/structures/event-structure.html
And an important page on Caveats and Recommendations when Using Events in LabVIEW
https://www.ni.com/docs/en-US/bundle/labview/page/caveats-and-recommendations-when-using-events-in-l...
I'll be reading the Caveats and Recommendation and event driven programming in LabVIEW pages today myself.
___________________________________________________________________________________________________________________________________________________
Upgraded from intern to undergrad automation engineer. Attempting to explain to my employer why I need official training…. since I’m the groups only automation engineer.
I tried. I really did.
(2,212 Views)
