Run time engine install from build package failure
when trying to install LV 8.0 Run Time engine from build package, an error is generated that the target computer needs to have LabView 8.0 installed.
i have verified that the run time engine is included as an additional installer under the build project.
(3,063 Views)
Hi MJK34,
If you are being prompted to install LabVIEW there must be something in the build that requires LabVIEW, not just the runtime.  Can you post a screenshot of your build specification?  Thanks.
Stephen S.
1 Test is worth 1000 expert opinions
(3,046 Views)
i have found a checkbox option in the builder options where an installed labview on the target machine is required.  after doing a new build, the installation went smoothly so this must have been the problem.
thanks,
(3,032 Views)
Great!
Stephen S.
(3,008 Views)
