folder of application builder(*.exe) with run-time DLL
My application consists of main.vi, subvi folder, and example folder.
In addition, I have to add the run-time libraries for add-on tool kit (advanced signal processing, lvwa.dll) which should be located in the root folder.
(For exe application, can I set the location of DLLs to not the root folder but "DLL folder"?)
In my several trials, I can't maintain the hierachy of "example folder".
Instead of my intension, the NI application builder copied the files in the folder to the support directory.
Can I locate the "example folder" to the root folder by using NI application builder?
In summary, I want to get the folder structure by application builder.
main.exe, DLL folder, Example Folder.
메시지가 08-08-2008 01:30 AM에 labmaster에 의해 편집되었음
(2,551 Views)
Hey Labmaster,
What version of LabVIEW are you using?
I am not too clear as to what you are trying to do. You can create folders and add anything from your project when creating an installer under the Source Files section in its properties.
It might be easier if you'd attach a screen shot of what you are doing or trying to do.
Aashish M
CEO
TransferFi
www.transferfi.com
(2,510 Views)
