Running a LabVIEW executable on UDOO x86 ii
I am wondering if I could run a LabVIEW executable on an UDOO single board computer?
Any ideas?
Many thanks.
Message 1 of 20
(1,014 Views)
Can I use UDOO x86 ii single board computer to run my labview executable?
Message 2 of 20
(1,004 Views)
Hi ahmadibra,
Does it come with a Windows10/11 environment as needed by your LabVIEW executable?
Message 3 of 20
(998 Views)
Hi GerdW,
Thanks for your reply. Yes it comes with Windows 10/11. Do I need anything else for it to be compatible?
Kind regards,
Ahmad
Message 4 of 20
(992 Views)
Hi Ahmad,
I guess no, never worked with such a SBC…
As long as it is standard Win11/x64 it should be able to run "standard" LabVIEW IDE and executable+runtime…
Message 5 of 20
(978 Views)
Hi GerdW,
Thanks for the prompt reply. Also one question; have you had experience running labVIEW on any SBC? I am asking since it does not have to be UDOO. I just want confirmation that I can run labview on any sbc. I have budget to buy one, whatever it is. Have you had experience with this?
Kind regards,
Ahmad
Message 6 of 20
(967 Views)
Hi Ahmad,
No. I work with standard Windows computers and cRIO/FPGA hardware.
But you can find specifications for LabVIEW by NI: your computer should run (standard) Windows11 to allow for "LabVIEW for Windows".
(I don't think there are AppleOS SBCs. And there are also specs for the "LabVIEW on Linux" edition, so the same rules apply…)
Message 7 of 20
(956 Views)
Kind regards,
Ahmad
As long as the SBC is a standard x86, then it should work. I have used a VersaLogic SBC in the past for a LabVIEW exe and it worked just fine. Just note, some of these embedded systems have limited resources, RAM, CPU, etc, so pay attention to your program design.
Message 8 of 20
(908 Views)
Some people advised the LattePanda.
The earlier models are fan-less, so no moving parts, but still pack some power.
The V1 LattePanda V1 (maybe other models too, >$105) has an onboard Arduino (ATmega32u4) "co-processor". It can be programmed to do IO OoTB.
Message 9 of 20
(855 Views)
Do you mean I have to check how much RAM, CPU power my labVIEW programme/executable takes?
Many thanks,
Ahmad
Message 10 of 20
(851 Views)
