Running a USRP without a Host PC
Hello all,
Does anyone know if it is possible to have a USRP 294x/295x run a custom bitfile on startup, without having a host PC connected? Would it be possible to load a custom bitfile onto the flash, or would that just "brick" the device?
Thanks!
(2,208 Views)
Hi aschwirian,
This should help you out.
If you ever feel like your USRP is 'Bricked' then you an always reset it.
(2,149 Views)
