Running a real time vi from the host vi
What is the absolute simplest way to automatically run the real time vi on my single board rio from my host vi?  I would like to have the rt vi deploy and run at the same time that I run the host vi.
(4,096 Views)
Hey MechHead,
The easiest way to do this would be to use VI Server to call the RT VI from the Host VI. All that you need to do is make sure the RT VI is deployed to the RT Target.
These documents may be of some use to you.
How do I Start my Real-Time Application without Setting it as a Startup Executable
http://digital.ni.com/public.nsf/allkb/F64D92E0BCA34162862573BD0072F807?OpenDocument
How to Programmaticall Launch a VI on a Real-Time (RT) Controller
 http://digital.ni.com/public.nsf/allkb/A7DBA869C000B5AE862570B2007C4170?OpenDocument
Hope this helps!
Logan H
(4,057 Views)
