Running multiple .exe after installer using .bat file
Hi there,
I created a batch file that should run executables sequentially. The problem is that the batch file is run in the wrong directory. It should be run in 'ProgramFilesFolder\COLLIN\installers.bat', but instead it is run in the installer directory. I could use "cd 'C:\Program Files (x86)\COLLIN\installers.bat'" but that would mean you can only install it in the default folder. Is it possible to include the executable files to the installer or is there another solution?
(4,394 Views)
Accepted by topic author Ongelofeloos
Check the help of the Advanced settings:
    • Command line arguments—Specifies the arguments to send to the application you want to run after the installation is complete. For each argument that represents a path, enclose the argument with quotation marks because paths can contain spaces. In addition to specifying standard arguments, you can embed any of the following variables in the Command line arguments field.
      Command-Line Argument Description
      [INSTALLDIR] Application installation directory that the user selects.
      [DISTROOT] Full directory path containing the setup.exe file that launched this installer.
      If any of these strings are present at installation, the installer replaces them with the correct values before it sends the arguments to the application
I guess that [INSTALLDIR] is what you are searching for. You can use the passed parameter in the bat or cmd file specifying "%1" in a command text.
Paolo
(4,363 Views)
So I put [INSTALLDIR] as a command line argument and in the .bat file I write "%1/executable"?
(4,336 Views)
I would use "%1executable_name", since [INSTALLDIR] includes the trailing separator according to the help.
For a test, put
pause
as the last cmd line. The command prompt window will not close, waiting for you to press a key. This will allow you to check what's the final command.
Paolo
(4,333 Views)
When my batch file looks like this:
@echo on
cd /d "%1"
"%1Newport.XPS.CommandInterface_x86.exe"
"%1Newport.XPS.CommandInterface_x64.exe"
"%1uEye_49610.exe"
"%1"Newport.XPS.CommandInterface_x86.exe
"%1"Newport.XPS.CommandInterface_x64.exe
"%1"uEye_49610.exe
uEye_49610.exe
pause
I get the following result:
It does not seem like it wants to switch drives or directories. Also %1 doesn't pass on the full path. It cuts when the first space appears.
(4,325 Views)
Figured it out. Had to put [INSTALLDIR] between quotation marks.
(4,318 Views)
From the 5th line you only have %1 in quotation marks, the full command must be in quotes, like in row 2-4.
Qestit Systems
Certified-LabVIEW-Developer
(4,314 Views)
