Running subVI in parallel with itself using producer-consumer pattern
I'm using the procuder-consumer pattern to create what I call threads in response to various events much like in Producer Consumer with Event Structure and Queues
I have several physical instruments, and would like to run the exact same test in parallel on each of the instruments.  I have a subVI that takes as inputs a VISA resource and a few control references among other things and then performs the desired experiment.  I have a separate consumer loop for each physical instrument, with this subVI inside each consumer loop.
My test VI worked great; each consumer loop was a simple while loop incrementing a numeric indicator (not using my real subVI above).  However, my real program can only run one consumer loop at a time much to my dismay.  Reworking my simple test VI to use a subVI to increment the indicator rather than just explicitly coding everything resulted in the same problem: only a single consumer loop ran at a time (and as I stopped the running loop, another would get a chance to begin). The subVI in this case was extremely simple taking only a ref to the indicator and a ref to a boolean to stop, and incrementing the indicator in a while-loop.
Is there a way around this?  Now that I've spent the time making a nice subVI to do the entire experiment on on the physical instrument, I thought it would be fairly trivial to extend this to control multiple instruments performing the same experiment in parallel.  It seems only one instance of a given subVI may run at one time.  Is this true?  If it is indeed true, what other options do I have?  I have little desire to recode my subVI to manually handle multiple physical instruments; this would also result in a loss of functionality as all parallel experiments would run more or less in lock step without much more complexity.
Thank you.
(2,918 Views)
You need to make your subvi reentrant.  Then it can run several instances at any time with each instance occupying its own unique memory space.  Click on File - VI Properties - Execution, and check the reentry execution checkbox.  Then save the vi.
- tbob
Inventor of the WORM Global
(2,915 Views)
My mouse clicking finger thanks you immensley.  Works perfectly of course, thanks.
(2,910 Views)
