I am running an array of transducers that require me to run two PCI boards installed in my PC to get the required number of channels. I need to be able to take data from both cards at the same time, at high sampling rates >10000S/s. If I try to take data from two boards LabVIEW takes data from the first board and after completing it then goes on to take data from the second board. Is this possible using a simple "Export to Spreadsheet.vi" The data speeds and accuracy seem fine the data is just not being taken from all channels all at once. I am hoping for a software solution.
