Runtime Error while installing NI FBus Software on Laptop with Win7/64bit
I am not able to install NI-FBus software im my laptop(Win7-64 bit) as its giving me the below mentioned error:
Please let me know about this issue and how to resolve it.
Thanks & Regards,
Sushruth.
Message 1 of 15
(3,413 Views)
you've forgotten to post the error.
Philipp
Message 2 of 15
(3,405 Views)
I have attached a document containing snapshot of the error. Please help me out regarding this.
Thanks & Regards,
Sushruth
Message 3 of 15
(3,401 Views)
Accepted by Sushkatta
Dear Sushruth,
Which version are you trying to install? Please notice that versions beyond 4.0 are supporting this operating system. Does the installer come further on another PC? You don't have to install the software only look if we can produce the error on another PC (another OS?).
If you see the same error on another PC, can you try to copy the contens of the CD to your harddrive and install it from there? We can also try to download a new installer and see if we have a better result.
Martijn S
Applications Engineer
NI Netherlands
Message 4 of 15
(3,389 Views)
Hi Martijn,
I am trying to install NI-Fbus software which contains NI-Fbus Communications Manager(4.0.1), Configurator(4.0.1) and Monitor(4.0). I was able to install it successfully on Windows XP(desktop). But when I tried installing it in Laptop(Win7-64bit) it gave a runtime error. The attached snapshot gives the error details. I tried to run it with Windows XP mode. But it failed again. I have not yet tried with the installer link you have given. For me if I get a trial version of it is also fine since I was trying to install registered version given by my company. Please let me know if you fina a solution to this problem.
Thanks & Regards,
Sushruth,
Student Intern,
KEMA, Nederlands.
Message 5 of 15
(3,384 Views)
Dear Sushruth,
Pleaser try copieng to the harddrive and if that doesn't work try the download link.
Martijn S
NI Netherlands
Message 6 of 15
(3,380 Views)
Dear Martijn,
Thanks for the swift reply. I will try to install after copying ht econtents from the CD. Will let you know if it was successful or not.
Sushruth.
Message 7 of 15
(3,375 Views)
Hi Martijn,
Thanks for the solution. I downloaded the latest version of FBus Configurator. it installed perfectly.
I need one more favour. Is it possible that  the results or graphs obtained from LabVIEW to publish online?
Best Regards,
Sushruth.
Message 8 of 15
(3,363 Views)
Deas Sushruth,
thank you for your feedback; great to hear that the problem has been resolved.
For online publishing you can use webservices or remote panels. For the last option you need to install the Labview run time engine from every PC you want to acces the front panel through the internet browser.
Martijn S
NI Netherlands
Message 9 of 15
(3,354 Views)
Thanks Martijn.
Message 10 of 15
(3,351 Views)
