Runtime R6025 Error
I created a program in LabVIEW. I created and tested the executable file of the program on the computer with LabVIEW development software and everything ran find. However, when I copy the exe file an its associated file to another computer (with Runtime engine and NI MAX installed), I have a Runtime Error R6025 when I run the executable file. Below are the details of my project
Computer with LabView development software.
       Windows 7 OS (64-bit)
       LabVIEW 2013 (32-bit)
Computer A with just Runtime Engine and DAQmx installed
       Runtime Engine 13. Downloaded fromt his link http://www.ni.com/download/labview-run-time-engine-2013/4059/en/
       NI MAX version 15
Computer B with just Runtime Engine and DAQmx installed
       Windows 7 OS (32-bit)
       NI MAX version 15
Error:  There are actually two errors popped up. One is "Runtime Error.....".  The other one is "Runtime Error! ..... R6025 - Pure virtual function call."
Any help is greatly appreciated.
(6,638 Views)
Can you post  full error messages?
What is in the VI? Like hardware type, .net calls...
Can you localize the problem to single subvi and build simple exe with basic operation?
(6,626 Views)
Hello Alexander,
The error message is attached. To update you with the symptom, I just ran the exe file on the development computer, the same error popped up as well. This program is rather simple. I have a USB NI 6008 module to monitor/record two analog inputs and control 3 digital outputs. The only sub VI I use is the express VI for DAQ assistant. The application is attached. This is a bit puzzelling to me. I will try to localize each function as suggested to see if anything changes.
Thank you for the help.
(6,621 Views)
Do you have MAX to try 6008 in test panel?
(6,619 Views)
Yes. I have it connected right now.
(6,616 Views)
Just an update. I looked at the code again and saw that I was writing to the DAQ output channels simultaneously. I fixed that and everything works now. Thank you for all the help.
(6,538 Views)
