SB-rio 9636 write to onboard SD-card
Hi, I've bought a SB-rio 9636 for my measurements. I want to use the onboard SD for data storage. However I'm not able to see the SD-card in MAX. Searching NI-forums and the internet has given me no solution or hints so fare.
Has someone a link to a tutorial or experience how to use (mount, read and write) the onboard SD facility.
Best regards
Christian
(4,212 Views)
Hi Christian,
You should be able to access the SD-card with a normal "Write/Read to/from Text file.vi" the typical drive path should be U:\
For example you could create a file at U:\Filename and write and read that file.
I also attached you a example project, please have a look at that.
Let me know if you need further information.
kind regards,
Markus
(4,182 Views)
Spoiler
Thanks for the reply i will explore your example. There is, due to heavy workload, some delay but i hope to solve this before next year.
(4,154 Views)
I'm trying to test but working with lv2011 and get an error saying my lv version is older dan use in the example. You are probebly working with lv2012, so it won't open.
Would you convert the example to lv2011.
regards Christian
(4,141 Views)
Accepted by Christian_M
Hi Christian,
attached is the lv2011 version
kind regards,
Markus
(4,136 Views)
Done testing and is now working in my system. Thanks for your help
Christian
(4,112 Views)
