SCPI commands work with Keysight IO but not NI Max
A piece of Keysight E5071C codes was resued for E5080A with code Emulator.
There were 3 traces on the screen at the beginning. Command
:CALCulate:PARameter:COUNt 5
is working with Keysight I/O but not with NI Max. ENA5080 has error message SCPI 106 with NI Max same as Labview.
Keysight E5080A FW A12.60.03.
Any suggestion?
GTR
(2,988 Views)
Hello GTR,
When you write *IND?\n in a NI-VISA Test Panel, what reads out? Can you show us a screenshot of your error message? A little more information will be helpful in narrowing down the issue.
Marina B.
Technical Support Engineer
www.ni.com/support
(2,936 Views)
You didn't say what interface you were using, but I have found that Agilent/Keysight needs to have the "Tulip Passport" enabled in NI-MAX.
This is the only "Passport" that is disabled by default
Open NI MAX
Navigate to Tools---->NI VISA---->VISA Options
Select Passports from the tree
Check the box to enable NiVisaTulip.dll -- NI-VISA Passport for Tulip
=== Engineer Ambiguously ===
(2,926 Views)
