SCXI 1302 pinout
Sooooo.
Im trying to find what pins are associated with what channels on a SCCXI platform. I didnt wire it, far too many channels and no lables or documentation (priceless)
I have 1302 terminal blocks, what pins are for what channels?
Message 1 of 9
(4,791 Views)
Message 2 of 9
(4,784 Views)
In Measurement and Automation Explorere you right click on the device and select 'pinouts'. Or search on the internet for the documentation of this device
Ton
My LabVIEW Ideas
Message 3 of 9
(4,782 Views)
The following Knowledgebase should answer your question fully...
Pinout for the SCXI-1302 50-Pin Terminal Block
Alex A.
Applications Engineer
Message 4 of 9
(4,771 Views)
Thank you. I have it working now.
Message 5 of 9
(4,761 Views)
@Alex A
I cant view this document. the error comes
"You are not authorized to view this document"
can you help with this?
Message 6 of 9
(3,781 Views)
The link in the earlier post was for an older knowledgebase that has since been moved or archived. I think the information that you need will be at the below page.
50 Pin SCXI-1302 Terminal Block Connector Mapping to 68 Pin E-Series DAQ Connector [broken link removed]
Ben R.
Aerospace & Defense Test
Solutions Marketer
Message 7 of 9
(3,768 Views)
Let's fix that link so that it is actually clickable.  (An extra HTTP was mixed in there.)
Message 8 of 9
(3,758 Views)
Thankyou so much guys. 🙂
Message 9 of 9
(3,748 Views)
