09-13-2007 09:37 AM
09-13-2007 10:44 AM
09-13-2007
11:28 AM
- last edited on
10-14-2025
09:00 AM
by
Content Cleaner
In Measurement and Automation Explorere you right click on the device and select 'pinouts'. Or search on the internet for the documentation of this device
Ton
09-13-2007
11:53 PM
- last edited on
10-14-2025
09:00 AM
by
Content Cleaner
The following Knowledgebase should answer your question fully...
Pinout for the SCXI-1302 50-Pin Terminal Block
09-14-2007 07:15 AM
07-20-2012 04:46 AM
@Alex A
I cant view this document. the error comes
"You are not authorized to view this document"
can you help with this?
07-23-2012
10:19 AM
- last edited on
10-14-2025
09:01 AM
by
Content Cleaner
The link in the earlier post was for an older knowledgebase that has since been moved or archived. I think the information that you need will be at the below page.
50 Pin SCXI-1302 Terminal Block Connector Mapping to 68 Pin E-Series DAQ Connector [broken link removed]
07-23-2012
12:47 PM
- last edited on
10-14-2025
09:02 AM
by
Content Cleaner
Let's fix that link so that it is actually clickable. (An extra HTTP was mixed in there.)
07-23-2012 11:33 PM
Thankyou so much guys. 🙂
