SFTP VIs in EXE
Good afternoon,
I'm having a lot of troubles with the SFTP library in LabVIEW. I'm using LV21 on Windows and I'm trying to build an executable which connects to a remote cRIO via SFTP, checks if there are any new files in a certain folder, and if so downloads them on my PC before deleting them on the cRIO, so that its memory doesn't fill up.
As long as I work with a simple VI, I have no problems at all doing all of the steps listed above, so I guess the code is ok.
But as soon as I build the executable I get the error shown in the picture attached, on all the SFTP VIs. I tried with other executables which also use these VIs and the issue is always the same.
I tried building the .exe file in different ways, tried it on different machines and I checked if it was an issue of my firewall blocking it, but nothing changes and I do not have any other ideas.
Thanks in advance to whoever might help.
Vittorio
(985 Views)
Hi Vittorio,
were you able to solve theis issue?
phil
(449 Views)
