fpga myrio plotting psd
hello, i wanted to use the FFT block in myrio fpga project. I should plot the spectrum density of the input signal, but unfortunately i couldnt do that. there is a few inforamation about it. Pls can u help me to figure it out? how should i use that block? should i convert the data from connector Ai1 to dbl and then input it as real data, and then connect it to z transform? ??? im really confused. i wish i could do just signal analysis and PSD, but i need to have it on FPGA. pls HELP. can u pls give me some example but without FIFO.
Message 1 of 1
(631 Views)
