SI 1260 : pb with sweep fmin<1Hz
Labview program for sweep measurement works with fmin>=1Hz but refuses to "read single" (time out) when fmin is put inferior to 1Hz. Why ? What is the blocking parameter using Read Multiple ?
(2,548 Views)
laetitia,
This is a very confusing post and I am not sure what your real question is. Are you using an instrument driver for a GPIB instrument? If so, which one? What version of LabVIEW are you using?
Please post a more clarified question so that we can respond. Thank you.
Randy Hoskin
http://www.ni.com/ask
(2,548 Views)
