SICK LMS511 Sensor
Hi everyone,
I have a SICK LMS511 Laser Sensor. The sensor is currently continuously scanning and returning all of the data from every scan. I am wondering if it is possible to have it send back ONLY the data regarding a specific event that I defined within the scanner back to my PC. We are communicating to the scanner over Ethernet.
***We are writing code for a stand-alone .NET application. We are not using LabVIEW.
Alex
(3,527 Views)
@sophisticatedlogic wrote:
Hi everyone,
Alex
I'd have to ask why, if you aren't using LabVIEW (or any NI products at all) you are posting in the LabVIEW forum...
You might have better luck contacting the supplier (SICK) regarding this, unless someone here has used that specific sensor and can help out.
(3,500 Views)
