What is the problem with Express Formula function under Script and Formulas palette?
Hello everybody,
I have a simple problem with Express Formula function under Script and Formulas palette.
I have installed LabVIEW 2016 on two different PC. In one of them I could find the Express Formula function as you see in picture number 1 attached to this post but it doesn't exist in the other system as you see in picture number 2.
What is the problem and how could I fix it?
Thank you
(3,668 Views)
I have never found a use for the express formula function, so I personally would not care. 😄
Were they activated the same way? (e.g. if you activate one as "LabVIEW base", it will contain fewer math tools (details), but I am not familiar with the detailed differences. Have you tried reinstalling? Did you get any errors during install?
What else is different between the two computers?
Can you run "NI MAX" and expand the software branch on each? Same with the NI license manager. Any differences between the two systems?
(3,641 Views)
It is a good news that you have never found a use for the express formula function.Smiley LOL
1-Yes,they were activated the same way.
2-I will try reinstalling in future.
3-The computers are similar in every aspects.
4-Yes, I can run "NI MAX" and expand the software branch on each.
5-Thank you for answering my question.
(3,574 Views)
