SIT-EXE Failure
I received a LabVIEW EXE-Application, this was build in LabVIEW 9 with SIT. The EXE-Application doesn’t works in my PC, The MALAB/Simulink software and the Runtime Engine 2009 are installed on the PC. When I try to run the application, this return: “Unable to connect the to the SIT Server in the Simulation environment” You can see the failure on the attach.
Did someone now this failure?
Thank for your Help
(2,612 Views)
Hi jeanjac,
did you follow the configuration procedure as described in the webcast Das LabVIEW Simulation Interface Toolkit – Teil I – Grundlagen?
Which version of the LabVIEW RunTime Engine are you (your executable) using?
Regards
TomBaum
(2,578 Views)
