how to append datas to a text file?
I want to append the data to a already created text file.When i used Write to text file.vi. It overwrites the previous data.
(3,075 Views)
Accepted by topic author jerryvdk
Try using the 'set file position' function (file io palette, advanced functions)  before you write the data.
i.e. open the file, set position to end, write the data, close the file.
Ian
(3,072 Views)
See the example here
(3,071 Views)
Thanks for ur help.That solved the problem
(3,066 Views)
