SIT Exhaustive Examples
where I can found exaustive examples for SIT.
I've created, from a Simulink model, a DLL that I would use stand alone.
How should I use the following blocks? (see attachment).
Thanks in advance.
Federico (Italy)
McTALAO
Message 1 of 8
(4,782 Views)
Frederico,
to get basic information enquire the Simulation Interface Toolkit help.
You can find the help in your LabVIEW development environment by browsing to the following point:
Help -> Search the LabVIEW Help... -> Browse in the contents tree to Toolkits -> Simulation Interface Toolkit.
I recommend to start with the How-To. After that move on to Simulation Interface VIs -> Model Interface VIs and User Interface VIs
ThSa
Message Edited by ThSa on 10-28-2008 12:37 PM
Message 2 of 8
(4,755 Views)
Hi ThSa,
i reat it and I didn't find examples for my work.
On my PC is not installed Matlab and I want to run the DLL, created with Simulink, in an independent manner.
I created the following VI, which runs the model for 10 seconds (see attachment).
I'm not sure if I made the right VI.
I doesn't know the potential of the blocks because I have not found examples.
Federico.
McTALAO
Message 3 of 8
(4,732 Views)
quick search
also see here
Message 4 of 8
(4,722 Views)
collect some info from the pdf in the attached zip
Message 5 of 8
(4,720 Views)
Hi Mathan,
I have another question...
I have a DLL compiled with Simulink, where I had specified the step simulation.
Is possible, from the DLL, extrapolate information on the step of the simulation?
Federico.
McTALAO
Message 6 of 8
(4,681 Views)
It depends on the dll. Am not sure about that. Could you please attach that dll?
Message 7 of 8
(4,678 Views)
OK.
The simulation time step is 0,01 sec (Simulink --> FIXED STEP SIZE: 0.01).
Federico.
McTALAO
Message 8 of 8
(4,674 Views)
