panel close
Hi
   I have a vi running.In the front panel if i close the Vi by clicking right top corner red X closing option it should ask for option to close the Vi or not if i give yes it should close if i give no it should not close the vi.ultimately user need to take the control to close or not after clicking the window close button
(3,628 Views)
drop an event strcuture on your block diagram and add the event "this vi -> panel Close?" use the event with the question mark and the red flag.
On the right is a box with "discard" in it. wire a TRUE to this. when the X is clicked by the user, LV will ignore the request. instead you can send a quit command to your consumer loop, or state machine, or whatever strcutures you are using 🙂
_____________________________
- Cheers, Ed
(3,623 Views)
thank you it is working
(3,603 Views)
