SMTP Email Palette - Subject text format
Using the SMTP Email palette, if I include a colon in the string wired to the Subject input of 'Set Message Text Html.vi', it shows up as a question mark in the email Subject in the recipient's inbox.
For example, sending "Test Completed at 10:00AM" as the email subject turns into "Test Completed at 10?00AM" on the receiving end.
How do I properly format the Subject string to get a colon on the receiving end?
Message 1 of 11
(7,255 Views)
I get it too. I think the problem lies in the Set Message Text.vi within the SMTP pallete. I can't get to the block diagram because it is password protected but it appears to come in correctly on the front panel.
Edit: Nope, I get it on the SMTP Express VI too.
Message 2 of 11
(7,229 Views)
What version of LabVIEW are you using?  What operating system?  Do you have additional languages set, besides English, on your computer?
Jonathan R.
Applications Engineer
Message 3 of 11
(7,160 Views)
I've got 2014 SP1 32-bit on a WIn 7 64-bit and using MS Outlook 2010. Only English is set on my PC.
Message 4 of 11
(7,147 Views)
I am running:
LabVIEW 2015 32-bit (v15.0.0)
Windows 7 Pro 64-bit
As far as I know, English is the only language I have installed.
Message 5 of 11
(7,118 Views)
I believe the colon is reserved in smtp as a field delimiter character.
You might be able to make the colon literal by placing a backslash immediately before it.
Something like "Test Completed at 10\:00AM"
Message 6 of 11
(7,104 Views)
Phillip,
I tried your suggestion and I get the same behavior as before but with the back slash. I've tried this with other programming languages (without the back slash) and I get the colon as expected.
I don't want to take away from MStewart's post but I'd figure I'd weigh in...
Eric
Message 7 of 11
(7,063 Views)
No worries Eric, glad to know I am not the only one having this issue.
I am getting the same result when I use the backslash.
"Test Complete at 10\:00" turns into "Test Complete at 10\?00"
Message 8 of 11
(7,049 Views)
Accepted by MStewart
The : (colon) is definitely a reserved SMTP field character.
You can customize the Subject content by encoding it as 8-bit and then use the hex value for colon (3A) to encode the colon. Try the exact subject text below; it worked for me using gmail.
=?iso-8859-1?Q?Test completed at 10=3A00 AM?=
https://en.wikipedia.org/wiki/MIME#Difference_between_Q-encoding_and_quoted-printable
Message 9 of 11
(7,028 Views)
You frequently see colons in subject lines, but as a part of an RE: or FW: added to the subject.  So it's not like it isn't regularly used.  But is it reserved because it needs to treat the foward/reply prefix specially?
Message 10 of 11
(6,999 Views)
