SMTP client shows BCC recipients in sent e-mails
I have had similar trouble with the NI SMTP client before (link). Now I figured out that the recipients from BCC field are exposed in the sent e-mail. Therefore, recipients can see all other recipients. At least in the couple of tests that I did. Nothing much one can do wrong with this test, as you only have to enter one or more recipients in the following VI:
I tested with lv 2015 & 2017 32 bits. I only used my domain smtp server for now.
I hope someone can advise me on a more robust solution to replace SMTP, or this SMTP library.
(4,324 Views)
I have the same result using the NI SMTP client, but was successful in hiding the BCC recipients by modifying the Gmail example found here:
https://forums.ni.com/t5/Example-Code/GMAIL-vi/ta-p/3996207
I changed the 'MailMessage' property node from 'CC' to 'Bcc' and sent an email from an Office 365 address to multiple recipients, without revealing other recipients addresses.
(4,287 Views)
Thanks for the alternative solution! I'll give it a go.
Still, a Labview built-in toolkit should not have such quirks
(4,272 Views)
I wouldn't call that a "quirk" - I'd call it a "bug" - and a potentially devastating one, at that.  Not devastating code-wise, but ramification-wise.
Bill
CLD
(Mid-Level minion.)
(4,257 Views)
My test was not conclusive enough for me to claim it to be a bug. But if others can concur, then it sure is one.
(4,241 Views)
