SPI Example Not Working (SCLK, MOSI, CS)
Do you have a working SPI reading on cRio9075 and 9401? Please send me your project, because I also have some SPI reading problem with the same equipment. I would be very thankful if you can do that.
Message 11 of 13
(904 Views)
I never did get it working. So, I cannot send you code.
My projecte actually was finished with different hardware and programming software. I actually decided for several reasons that the cRIO9075, 9401 and Labview was not the correct solution for what I was trying to accomplish.
Message 12 of 13
(888 Views)
Hi mosbif,
There libraries and examples available for working with SPI on the 9401.
FPGA IP (IPNet): Digital Buses and Protocols (SPI, I2C, and Serial)
This resource provides FPGA IP for using digital buses and protocols.
SPI and I2C Driver API - National Instruments
This resource is another driver from SPI communication with the 9401 and includes examples.
David B.
Applications Engineer
Message 13 of 13
(875 Views)
