SPI interface with ATMEL AT45DB3
Hi all,
I am trying to interface AT45DB3 with a simple labview program that should read out the manufacturing code of the chip. The running of this program results in FF instead of 1F. I tried different ways, but no luck in reading out the right code. Can someone help me with this? I am attaching the current labview VI if anyone wants to take a look at it. Thanks.
~Vmin
(2,920 Views)
Hello vmin:
Have you tried running a shipping example in LabVIEW. For example the General SPI Write(or Read).vi. Does the same problem occur?
Message Edited by Roland A. on 11-13-2007 02:37 PM
Roland A.
Applications Engineer
Check out VI Roadshow
(2,884 Views)
Not really. But, how will that make a difference? i have used the same .vi but just modified a little bit. I will give that a try though. Thanks.
~Vmin
(2,862 Views)
