SPI write 16 bit
I wrote code a few weeks ago using this library that re-configures the number of bits (although I only use full bytes) and it works fine. Can you share your code?
Message 11 of 15
(608 Views)
This is the code:
I send two bytes: xC0 xC0 Followed by seven bytes x02 x28 x87 xFA x00 x00 x00
I want CS reset high between the two sequences
I obtain the first frame OK
the second frame is truncated at 2 bytes x02 x28
In fact it is truncated at the length secified in the first configuration VI
Thanks for your help
Best regards
Thierry
Message 12 of 15
(606 Views)
Hi Thierry,
The API consists of FPGA VI´s and RT VI´s.
Open a new VI in FPGA. Go to Connectivity -> SPI -> SPI Engine. Place it in your VI. Configure your SPI FPGA IO and compile it.
Then open a new VI in RT. In your case, the RT VI could look like in the picture I uploaded.
GM_1
Message 13 of 15
(598 Views)
Hi GM_1
I have tested this solution; It works, but the problem is that I have 12 ms between the two sequences (frame C0, C0 and frame 02, 28, 87, FA, 0, 0, 0)
This delay is absolutly unacceptable in my application and I have no idea of the reason of this delay
It is the reason why I was trying to make all the sequence inside the FPGA
Any idea of the reason of this delay?
Best regards
Thierry
Message 14 of 15
(590 Views)
SOLVED!!
The only thing to do was to introduce a small delay (few µs) before a re-configure, doing this it is taken into account
Thanks to GM_1 and Nathand for their help
Best regards
Thierry
Message 15 of 15
(574 Views)
