SQL Query
Hii
 I am having one MYSQL database in that i am having one column in a table as Status which has
1.Pending
2.Pending
3.over
4.over
5.Pending
  Likewise now i want to took the Pending data alone in MySQL database ..
  Now i want to know the query for that.....
(3,286 Views)
You should look at some of the many SQL tutorials on the web. Your question
doesn't seem to be LabVIEW related, although it's not really clear what you
mean.
Normally:
SELECT columnname FROM tablename;
Should get you the results from one column.
Wiebe.
(3,258 Views)
A good SQL tutorial that I've used many times over the past few years is at http://www.w3schools.com/sql/default.asp.  That should get you through an introductory level.
Greg
Certifed LabVIEW Developer
(3,231 Views)
