labview.ini
How can I do to have each user its own labview.ini file ? And of course bee able to edit it.
I first copy a file labview.ini into a "home" directory and use a shortcut which is supposed to start Labview from
the same "home" directory, But still Labview does not use it. I probably need to change something else maybe in the regedit.
Thank
(3,330 Views)
From the online Help:
LabVIEW stores options in a labview.ini file in the LabVIEW directory. The file format is similar to other .ini files. It begins with a LabVIEW section marker followed by the option name and the values, such as offscreenUpdates=True.
If you want to use a different options file, specify the file in the shortcut you use to start LabVIEW. For example, to use an options file on your computer named lvrc instead of labview.ini, right-click the LabVIEW icon on the desktop and select Properties. Click the Shortcut tab and type labview -pref lvrc in the Target text box.
(3,314 Views)
See LAVA Wiki entry about labview.ini file
LabVIEW, C'est LabVIEW
(3,280 Views)
