Showing results forĀ
Search instead forĀ
Did you mean:Ā
SQL Timeout during INSERT - Citadel Archive
I have a problem during an INSERT in a SQL Server 2005 database. I get a timeout because another computer fetches data from the citadel db which is also running on the host where the sql query is executed. It seems that the Citadel archiving process reserves the whole capacity of the host and that the sql-query has no time to be executed.
What's going on here? Suggestions
Kind Regards,
Joachim
(4,457 Views)
Dear Joachim
That's interesting: are you saying that you have one machine hosting two
databases (one SQL Server, one Citadel) and only one of these can be accessed
at one time?
Best regards
Philipp Roessler
(4,425 Views)
Hi Philipp,
Yes exactly - one host for a citadel and sql-server 2005 database - and during achiving data from citadel to another host no querys on the sql-server database are possible.
Kind Regards,
Joachim Schreibmaier
(4,417 Views)
Dear Joachim
I'd like to resemble your issue on my computer, so please provide us with
some more details:
1. You're archiving the Citadel database as explained on
http://digital.ni.com/public.nsf/websearch/E076A0661E03F1EB862571A800079E7B?OpenDocument,
right?
2. Can you reproduce the behavior when you do both the Citadel archiving
and the SQL Server querying locally on the same machine?
3. Which Citadel version do you have?
4. How do you access the SQL Server database?
Best regards
Philipp Roessler
(4,393 Views)
