[SQLite] Search multiple columns in a table and display selected results
Hi everyone,
I am developing a LabVIEW application using SQLite for a data logging and analysis system.
The goal of my application is to allow users to search across multiple columns in a table using partial text matching, and also to let users choose which columns should be displayed in the final results.
In my current implementation, I am using the following SQL statement to search across multiple columns:
SELECT *
FROM RawData
WHERE BodyPart LIKE ? OR Position LIKE ? OR Phase LIKE ? OR DateTime LIKE ?;
However, I am running into an issue when trying to use "Bind Text" in LabVIEW. Although I can prepare the statement successfully, I am not able to correctly pass multiple parameters for filtering as expected. ONLY % work ....
I have attached my VI and database file for reference.
Any advice on how to properly handle multiple parameters with SQLite in LabVIEW would be greatly appreciated.
Thanks!
(197 Views)
What result do you expect? If you bind even a single %, any row will match.
Does it work correctly if you change the default query for each column to an empty string?
(172 Views)
Accepted by topic author ChenTW
Your SQL statement is expecting 4 bound parameters.  If you want to only bind one parameter and use it in 4 places then you need to specify it with '?1' rather than '?':
SELECT *
FROM RawData
WHERE BodyPart LIKE ?1 OR Position LIKE ?1 OR Phase LIKE ?1 OR DateTime LIKE ?1;
This indicates you are using the first bound parameter in 4 places.
(152 Views)
Thank you for your reply.
I want to use these four items as filters. I found my issue,it should use AND instead of OR.
SELECT *
FROM RawData
WHERE BodyPart LIKE ? AND Position LIKE ? AND Phase LIKE ? AND DateTime LIKE ?;
This achieves the result I want.
I’m not very familiar with SQLite, so as you suggested, if I want to bind only one parameter and use it in four places, I need to specify it as “?1” rather than “?”.
Is there any documentation or manual related to “?1”? I would like to learn more about how to use it.
Thank you again.
(117 Views)
Section 4 of this link is about Parameters: https://sqlite.org/lang_expr.html
(51 Views)
