SR810 labview
I am using an official Labview VI for the SR810 lock-in amplifier. It is attached below. Screenshot also attached.
I am new to Labview and I would like to be able to have a stop button in this VI instead of having to press the the program stop on the ribbon.
I presume I can put a while loop around SR830 - All Parameters subroutine or is this not the correct way to do this?
Nevica
Message 1 of 10
(8,917 Views)
Put the initialize and close outside the while loop with the other code inside it, use an or gate to combine the stop button with other code used to detect an error so that either an error or pressing the stop button will stop the program running - Mike
Message 2 of 10
(8,914 Views)
Nevica,
Can you please tell me if you found the official LabView VI's on the National Instruments site?  I am also using an SR810.
Thanks!
Message 3 of 10
(8,734 Views)
Hello FN,
No, I didn't. I wrote one myself!
nevica
Message 4 of 10
(8,718 Views)
Would you like the vi
Message 5 of 10
(8,705 Views)
Thank you, that would be helpful!
Message 6 of 10
(8,687 Views)
Here it is:
Made in Labview 2009
You'll need precise timestamp .vi as well
Message 7 of 10
(8,653 Views)
Thanks Nevica, have a nice holiday!
Message 8 of 10
(8,644 Views)
Hope it works for what you want
Message 9 of 10
(8,642 Views)
Dear Nevica
First of all, I want to express my gratitude. We are currently using your VI for the SR810 amplifier. However, while running the VI, we encountered an error stating, "The VI expects some dependent VI." I have attached a screenshot of the error for your reference. Could you please assist me with this?
Thank you.
Priya
Message 10 of 10
(4,089 Views)
