STFT (spectrogram)
Hello all!
 How can I convert frequency axis to period  axis (intensity graph), when STFT-data put into on intensity graph?
what is worth doing is worth doing well
Message 1 of 15
(8,537 Views)
How about connecting period to intensity graph 2D array and single click on frequency label to rename it Period ?
Will that work ?
Kudos are Welcome Smiley Wink
Thanks & Regards,
Kunal Raithatha.
CTD - CLAD (I wish I can take off that A, and maybe use it later to replace D 🙂
Easy Tip :- "To copy an image to a VI icon, drag the image file and place it on the icon
located in the upper right corner of the front panel or block diagram" ...If you know any
more reply back.
Message 2 of 15
(8,533 Views)
"How about connecting period to intensity graph 2D array and single click on frequency label to rename it Period " -it will not work.. I think.... ->
-> 2D array STFT-data -it's amplitude(magnitude) array, right? there delta F (step) is linear... (0,01 0,02)
if convert Frequency to Period, then delta Period (step) non-linear, because delaPeriod=1/delta(100 50) F(step increases nonlinear/irregularly).
How can I do it? averybody, help me...
Message 3 of 15
(8,518 Views)
How to compute 2D array-amplitudes for periods? rather than frequencies...
Message 4 of 15
(8,499 Views)
what is needed, example:
How Can I do it??? anybody, help me  please.
Message 5 of 15
(8,481 Views)
To convert from frequency to period, you will need to resample your data along the Y axis.  LabVIEW includes a number of resampling algorithms, one of which should work for you.  Process your data a vertical line at a time using one of them and you should be good to go.  Given the fixed nature of the resampling, you should be able to make this quite efficient.
Message 6 of 15
(8,455 Views)
->this does not work... no ideas...
1. invers array,
2. setting Y scale.->
Message 7 of 15
(8,425 Views)
Hi borvsk,
How is the bottom graph not what you wanted? That looks like it is giving you the period of the frequency graph above. Please explain in more detail.
Jason L.
Product Support Engineer
Message 8 of 15
(8,411 Views)
100Hz-0,01sec - good. 200Hz- 0,008sec -bad, 400Hz - 0,0025sec-good 300Hz-0,005sec- bad
100Hz=0,01sec, 200Hz=0,005sec, 400Hz=0,0025sec, 300Hz=0,00(3)sec.
Message 9 of 15
(8,402 Views)
Hi borovsk
I see what you mean in that it is incorrect. Do you mind posting a snippet of your block diagram? I think it would be beneficial for us if we can see that portion.
Jason L
Message 10 of 15
(8,393 Views)
