STFT (spectrogram)
I took into account the what DFGray proposed ... and here result(see attachment file).
And it's not bad working,but not excellent.
what is worth doing is worth doing well
Message 11 of 15
(1,745 Views)
borovsk,
Sorry it's taking me so long to respond back to you. Why are you interpolating the data? It would be preferable if you were to attach the code you used for http://forums.ni.com/t5/LabVIEW/STFT-spectrogram/m-p/1750644#M611741, as your actual code is too cumbersome to read through. We need to take a step back and isolate just plotting the period of your waveformsH
Jason L
Product Support Engineer
Message 12 of 15
(1,721 Views)
Jason L,
I interpolating data, because I don't known how create irregularry axis Y on Intensity Graph. I attached old vi(1. invers array,
2. setting Y scale).
Message 13 of 15
(1,709 Views)
borovsk,
Thanks for attaching the code. It seems like when you reverse the array, the data reflects itself over the center of the Y scale. You can't just simply reverse the array and expect it to be the period, remember that the period is (1/frequency) which is not a linear relationship. Using this method, you would need to take the Y position of the frequency point and put it in the Y position that is it's reciprical.
Jason L.
Message 14 of 15
(1,699 Views)
Jason L,
You said:
"Using this method, you would need to take the Y position of the frequency point and put it in the Y position that is it's reciprocal."
You could help to implement it? I don't known how it will look.
Message 15 of 15
(1,697 Views)
